Configure IP Shortcuts on the boundary nodes.
Perform this procedure to configure Multi-area SPB IPv4 unicast redistribution on the switch.
Configuring Multi-area SPB IPv4 unicast redistribution for home to remote direction:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router isis
Switch:1(config-isis)#multi-area ip redistribute unicast home-to-remote
Switch:1(config-isis)#multi-area ip redistribute unicast home-to-remote route-map test
Switch:1(config-isis)#multi-area ip redistribute unicast home-to-remote enable
Switch:1(config-isis)#show isis multi-area ip redistribute home-to-remote
ISIS Multiarea Redistribute List for ip unicast - GlobalRouter
DIRECTION ENABLE RPOLICY
home-to-remote TRUE test
Switch:1(config-isis)#isis multi-area ip apply redistribute unicast home-to-remote
The following table defines parameters for the multi-area ip redistribute unicast and the isis multi-area ip apply redistribute unicast commands.
| Variable | Value |
| delete-tags | Disables the transmission of route tags in Multi-area SPB. Use this parameter if platforms do not correctly calculate the TLV length in TLV 135. By default, route tags are transported in Multi-area SPB. |
| enable |
Enables Multi-area SPB IPv4 unicast redistribution. |
| home-to-remote |
Specifies the IPv4 unicast redistribution configuration for home to remote direction. |
| remote-to-home |
Specifies the IPv4 unicast redistribution configuration for remote to home direction. |
| route-map WORD<1-64> |
Specifies the name of the route policy. |
| vrf WORD<1-16> |
Specifies the unicast redistribution configuration for specific VRF instance. |
